  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholders
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Part #
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
Haas VMC + Rotary
Product Image
GET QUOTE
DESIGNED TO WORK
TOGETHER
Your browser doesn't support HTML5 video.
5-AXIS SIMPLIFIED
  • ADD A ROTARY
  • VMC + ROTARY
  • 5-AXIS MACHINES
VMC + ROTARY + OPTIONS = READY TO GO
  • CM-1 + TRT70 = work cube up to 3"
    Adding the super compact TRT70 tilting rotary table to the CM-1 creates a high-precision, 5-axis package for machining small, intricate parts.
  • Haas VF-2SS + TR160 = work cube up to 10"
    Simultaneous 5-axis motion reduces the number of operations, cuts cycle times, and reduces the number of setups to increase accuracy and maintain conformity throughout a part run.
  • DT-2 + TRT100 = work cube up to 5"
    This high-speed, lean-style, 5-axis combination is perfect for producing complex, multi-sided small parts in volume.
  • VF-4 + TR200Y = work cube up to 8"
    The compact TR200Y is designed to mount along the Y-axis of the VF-4, leaving plenty of room on the table for vises and other fixtures.
    CNY ONLY
View Details | Get Quote
    CNY ONLY
    CNY ONLY
    CNY ONLY
“We bought the Haas UMC-750s because of the very attractive quality-to-price ratio. We make a lot of complex automotive parts, and needed five-axis machines that weren’t too expensive. The components tend to be big, so we purchased two Haas UMCs – one is running while the other is loading and unloading. They are arranged in a small cell, with one operator to run both.”
Alluminio Sammarinese
Stefano Ceccato | CEO | Alluminio Sammarinese
Don’t Fear 5-Axis - Transform Your 3-Axis Mill
DON’T FEAR 5-AXIS EP. 1
In the first video of our “Don’t Fear 5-Axis” series, John Nelson explains why 5-axis machining is much simpler than it has ever been, and why any shop can be a 5-axis shop.
DON’T FEAR 5-AXIS EP. 2
In the second video of our “Don’t Fear 5-Axis” series, John Nelson explains how to choose your machine and rotary combination, and discusses which options you should consider adding to make the most of your machine and rotary.
DON’T FEAR 5-AXIS EP. 3
In the third video of our “Don’t Fear 5-Axis” series, John Nelson talks about setting up your rotary table or trunnion, and explains how the Haas DWO/TCPC feature makes 4th- and 5th-axis work simpler than ever.
SIMPLIFY 5-AXIS MACHINING WITH DWO/TCPC
Our powerful DWO/TCPC (Dynamic Work Offsets / Tool Center Point Control) feature lets you create your CAM program ahead of time, and then place the workholding and part anywhere on the table, with no need to repost your program!
“At the start, we wanted a five-axis machine to differentiate ourselves from three main competitors we had identified in the market. But we needed to find a good machine at a good price, and we couldn’t afford to buy a new one. A pre-owned Haas VF-2 with TR160 trunnion proved to be the ideal solution.”
KMP
Sébastien Korczak | Owner | KMP
Still have questions? Ask away. We’ll hit you back with the answers.
Be as specific as you like, so we can help you find the best 5-axis solution for your shop.
FIND DISTRIBUTOR
  • Rotary Fit Chart
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
