  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Bar Feeder
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholders
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Part #
      Mill Toolholding Mill Workholding Milling Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
VMT-750
Product Image
GET QUOTE
VMT-750
    CNY ONLY
    CNY ONLY
Vertical Mill/Turn Machining Center; 31" x 13" x 25" travels
  • HSK-T/A63 Taper
  • 5 Axis
  • 8.1k RPM
  • 50+1 Tool Capacity
Coming soon. Contact your local HFO for availability.
Note: Pre-production specifications and dimensions; subject to change without notice.
Spindle-nose-to-table dimensions (minimum and maximum) will vary with the orientation of the spindle. See Machine Layout Drawing.
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Torque Chart
Standard Features
  • 8100-rpm Spindle, HSK-A63, Grease Packed
  • 50+1 Side-Mount Tool Changer, HSK
  • Wireless Intuitive Probing System
  • Automatic Tool Presetter
  • Window Air Blast
  • Chip Auger
  • 55-Gallon Coolant Tank
  • CNC Control Cabinet Cooler
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Available Options
The Haas VMT-750 vertical mill/turn center combines the rigid structure of our VF-3YT vertical machining center with the robust spindle of our ST-15 big-bore turning center to create a versatile multi-tasking center for machining medium-sized complex parts in a single setup.
  • Mill and turn complex parts in a single setup
  • HSK-T/A63 taper spindle w/brake for turning operations
  • 0-90º B-axis spindle rotation, interpolated or positioning
  • Made in the USA
VMT-750 HAASTEC DEMO
Check out these clips from our 2020 HaasTec Live event. We gave everyone a sneak-peek at the VMT-750 that is currently in development. The VMT-750 is a fully functional example of the direction Haas is presently taking toward the mill/turn segment.
Travels S.A.E METRIC
X Axis 31.0 in 787 mm
Y Axis 13.2 in 335 mm
Z Axis 25.0 in 635 mm
Spindle S.A.E METRIC
Max Rating 20.0 hp 14.9 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 150.0 ft-lbf @ 500 rpm 203.0 Nm @ 500 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper HSK-A63 HSK-A63
Bearing Lubrication Grease Packed Grease Packed
Cooling Air Cooled Air Cooled
B Axis – Tilt S.A.E METRIC
Travel 0˚- 90˚ 0˚- 90˚
Max Speed 50 °/sec 50 °/sec
Max Torque 1854 ft-lbf 2514 Nm
Brake Torque 1200 ft-lbf 1626 Nm
Spindle – Turning S.A.E METRIC
Chuck Size 8.3 in 210 mm
Spindle Nose A2-6 A2-6
Max Speed 4000 rpm 4000 rpm
Bar Capacity 2.50 in 64 mm
Spindle Bore ø 3.50 in 89.0 mm
Main Spindle C Axis S.A.E METRIC
Max Rating 5.0 hp 3.7 kW
Positioning (±) 0.02 ° 0.02 °
Brake Clamp Force 1000 lbf 4448 N
Brake Diameter 14.4 in 366 mm
Brake Holding Torque 140 ft-lbf 190 Nm
Control Type Interpolated Motion and Positioning Interpolated Motion and Positioning
Table S.A.E METRIC
Length 54.0 in 1372 mm
Width 24.0 in 610 mm
T-Slot Width 0.630 in 16 mm
T-Slot Center Distance 3.15 in 80 mm
Number of Std T-Slots 7 7
Max Weight on Table (evenly distributed) 3500 lb 1588 kg
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 710 ipm 18.0 m/min
Rapids on Y 710 ipm 18.0 m/min
Rapids on Z 710 ipm 18.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2550 lbf 11343 N
Max Thrust Y 4100 lbf 18238 N
Max Thrust Z 4100 lbf 18238 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 13 in 330 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 2.8 s 2.8 s
Chip-to-Chip (avg) 3.6 s 3.6 s
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Other Similar Machines
Haas ST-20Y
ST-20Y Turning Center Alternative
Y-Axis CNC Lathe with 11.75" x 22.5" max capacity and 2.5" bar capacity
  • 8.3" Chuck Size
  • 2.5" Bar Capacity
  • 4k RPM
  • 20 hp Power
    CNY ONLY
Learn More Build & Price
Haas UMC-500
UMC-500 A DIFFERENT APPROACH
5-Axis CNC Vertical Machining Center with 24" x 16" x 16" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Haas VR-8
VR-8 A DIFFERENT APPROACH
5-Axis Vertical Machining Center; 64" x 40" x 42", 2-axis head
  • HSK-A63 Taper
  • 5 Axis
  • 20k RPM
    CNY ONLY
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • Rotary Fit Chart
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
