  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
TM-1P
Product Image
GET QUOTE
TM-1P
    CNY ONLY
    CNY ONLY
CNC Toolroom Mill with 30" x 12" x 16" travels and ATC
  • 40 Taper
  • 3 Axis
  • 6k RPM
  • 10 Tool Capacity
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Rotary Fit chart
  • Gallery
  • Send Info
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • TM Series Flyer
Standard Features
  • 6000-rpm Spindle
  • 10-Pocket Carousel Tool Changer
  • Coolant Pump Kit
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • User-Definable Macros
  • Visual Part Programming System
  • Internal High-Voltage Isolated Transformer
  • Work Light
  • Convenience Package
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Available Options
The TM-P Series Toolroom Mills are affordable, easy to use, and offer the precision control of the Haas CNC system. They use standard 40-taper tooling, and are very easy to learn and operate – even without knowing G-code. They are the perfect option for schools and companies transitioning to CNC, or for anyone looking for a large-travel machine on a budget.
The TM-P models include a 10-pocket automatic tool changer, a faster spindle, and higher rapids.
  • Operates on single- or three-phase power
  • Conversational programming system
  • User-friendly Haas control
  • Affordable full CNC capabilities
  • HaasConnect remote monitoring
  • Made in the USA
The Haas TM-1
Haas Toolroom Mills are the true definition of value, providing full CNC capabilities – including available 4th- and 5th-axis functionality – at affordable prices. They offer the perfect combination of value, reliability, and performance for any shop – from schools to high-end manufacturers.
Travels S.A.E METRIC
X Axis 30.0 in 762 mm
Y Axis 12.0 in 305 mm
Z Axis 16.0 in 406 mm
Spindle Nose to Table (~ max) 20.0 in 508 mm
Spindle Nose to Table (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 7.5 hp 5.6 kW
Max Speed 6000 rpm 6000 rpm
Max Torque 33.0 ft-lbf @ 1200 rpm 45.0 Nm @ 1200 rpm
Drive System Direct Speed, Belt Drive Direct Speed, Belt Drive
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Grease Packed Grease Packed
Cooling Air Cooled Air Cooled
Table S.A.E METRIC
Length 47.8 in 1213 mm
Width 10.5 in 267 mm
T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
T-Slot Center Distance 4.00 in 102 mm
Number of Std T-Slots 3 3
Max Weight on Table (evenly distributed) 1000 lb 454 kg
Feedrates S.A.E METRIC
Max Cutting 400 ipm 10.2 m/min
Rapids on X 400 ipm 10.2 m/min
Rapids on Y 400 ipm 10.2 m/min
Rapids on Z 400 ipm 10.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 2000 lbf 8896 N
Max Thrust Y 2000 lbf 8896 N
Max Thrust Z 2000 lbf 8896 N
Tool Changer S.A.E METRIC
Type Carousel Carousel
Capacity 10 10
Max Tool Diameter (full) 3.5 in 89 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 5.7 s 5.7 s
Chip-to-Chip (avg) 6.5 s 6.5 s
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 100 in x 78 in x 101 in 254 cm x 199 cm x 257 cm
Export Pallet 100 in x 78 in x 101 in 254 cm x 199 cm x 257 cm
Weight 4500 lb 2042.0 kg
Spindle Speed 6000 rpm 6000 rpm
Spindle Power 7.5 hp 5.6 kW
Input AC Voltage (1 Phase) 220 VAC 220 VAC
Full Load Amps (1 Phase) 40 A 40 A
Full Load Amps (3 Phase) - Low 25 A 25 A
Full Load Amps (3 Phase) - High* 13 A 13 A
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
HAAS ROTARY HAAS MACHINE ROTARY FIT TYPE
HA2TS TM-1P ALTERNATIVE FIT: CAUTION
HA5C TM-1P ALTERNATIVE FIT: CAUTION
HA5CS TM-1P ALTERNATIVE FIT: CAUTION
HRT160-2 TM-1P ALTERNATIVE FIT: CAUTION
HRT160SP TM-1P POSITIVE FIT
HRT210SP TM-1P POSITIVE FIT
TRT100 TM-1P ALTERNATIVE FIT: CAUTION
TRT160 TM-1P ALTERNATIVE FIT: CAUTION
TRT70 TM-1P ALTERNATIVE FIT: CAUTION
HRT100 TM-1P POSITIVE FIT
TH240 TM-1P POSITIVE FIT
HA5C-T TM-1P ALTERNATIVE FIT: CAUTION
Talk to Us
Other Similar Machines
affordable alternative
Haas TM-1
TM-1
  • 40 Taper
  • 3 Axis
  • 4k RPM
  • 1 Tool Capacity
    CNY ONLY
Learn More Build & Price
LARGER WORK ENVELOPE
Haas TM-2P
TM-2P
CNC Toolroom Mill with 40" x 16" x 16" travels and ATC
  • 40 Taper
  • 3 Axis
  • 6k RPM
  • 10 Tool Capacity
    CNY ONLY
HIGHER PRODUCTION
Product Image
VF-1
CNC Vertical Mill with 20" x 16" x 20" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 20 Tool Capacity
    CNY ONLY
How to Square and Indicate a Vise
If you’ve ever struggled to set up a vise, or are not sure of the correct way to do it, this video is for you. Tip-of-the-Day expert Mark Terryberry shows you how.
Haas Wireless Intuitive Probing System
With the Haas Wireless Intuitive Probing System (WIPS), you can set tool and work offsets in a fraction of the time. No more edge finders or slips of paper under the tool needed.
How to Correctly Pick Up a Bore
In this video, Haas Tip-of-the-Day expert Mark Terryberry covers a topic that every machinist needs to know. Whether you are a beginner or an experienced pro, you will benefit from this video.
Use G53 Instead of G28 to Send Your Haas Mill to Home Position
Are you using a G28 command to send your machine table or tools to home position? In this Tip-of-the-Day, Mark demonstrates how using a G53 command instead not only saves valuable cycle time, but also reduces the risk of crashing your machine.
Replacement Parts
Replace worn out parts on your machine with genuine OEM parts. We have thousands in stock and ready to ship.
SHOP NOW
Performance Upgrades
Make your Haas machine perform even better, with high-productivity options that can be installed at your shop.
SHOP NOW
Maintenance Upgrades
Make your machine easier to operate, while reducing downtime. A variety of solutions are available.
SHOP NOW
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
