  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
VM-2
Product Image
GET QUOTE
VM-2
    CNY ONLY
    CNY ONLY
CNC Vertical Mold Machine with 30" x 20" x 20" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
  • 30+1 Tool Capacity
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Rotary Fit chart
  • Gallery
  • Send Info
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • VM Series Flyer
Standard Features
  • 12,000-rpm Spindle
  • 30+1 Side-Mount Tool Changer
  • Programmable Coolant Nozzle
  • Automatic Air Gun
  • Window Air Blast
  • Chip Auger
  • 55-Gallon Coolant Tank
  • Variable Flow Coolant
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • Safe Run
  • HaasDrop
  • Remote Jog Handle with Touchscreen Display
  • Rigid Tapping
  • User-Definable Macros
  • Coordinate Rotation and Scaling
  • High-Speed Machining
  • Internal High-Voltage Isolated Transformer
  • Table Auxiliary Air Supply
Warranty
  • 1-Year Standard Warranty
Available Options
The Haas VM Series machines are high-performance VMCs that provide the accuracy, rigidity, and thermal stability required for mold making, tool & die work, and other high-precision industries. Each machine features a generous work cube, a multi-fixturing table, and a 12,000-rpm inline direct-drive spindle. Standard features include the Haas high-speed control with full look-ahead, a side-mount tool changer, a programmable coolant nozzle, an automatic air gun, and much more.
  • Inline direct-drive spindle
  • Side-mount tool changer
  • Multi-fixturing table
  • High-speed machining software
  • Made in the USA
Travels S.A.E METRIC
X Axis 30.0 in 762 mm
Y Axis 20.0 in 508 mm
Z Axis 20.0 in 508 mm
Spindle Nose to Table (~ max) 24.0 in 610 mm
Spindle Nose to Table (~ min) 4.0 in 102 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 12000 rpm 12000 rpm
Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
Taper CT or BT 40 CT or BT 40
Table S.A.E METRIC
Length 36.0 in 914 mm
Width 18.0 in 457 mm
T-Slot Width 0.626 in to 0.630 in 15.90 mm to 16.00 mm
T-Slot Center Distance 4.38 in 111 mm
Number of Std T-Slots 7 in Y and 3 in X 7 in Y and 3 in X
Max Weight on Table (evenly distributed) 3000 lb 1361 kg
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 710 ipm 18.0 m/min
Rapids on Y 710 ipm 18.0 m/min
Rapids on Z 710 ipm 18.0 m/min
Axis Motors S.A.E METRIC
Max Thrust X 3400 lbf 15124 N
Max Thrust Y 3400 lbf 15124 N
Max Thrust Z 5600 lbf 24910 N
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 11 in 279 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 2.8 s 2.8 s
Chip-to-Chip (avg) 3.6 s 3.6 s
General S.A.E METRIC
Coolant Capacity 55 gal 208 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
Domestic Pallet 102 in x 106 in x 102 in 260 cm x 270 cm x 260 cm
Export Pallet 100 in x 92 in x 101 in 254 cm x 233 cm x 257 cm
Weight 9400 lb 4264.0 kg
Domestic Pallet w/50+1 SMTC 102 in 106 in 110 in 260 cm 270 cm 279 cm
Export Crate w/50+1 SMTC 102 in 109 in 116 in 260 cm 277 cm 295 cm
Weight w/50+1 SMTC 9700 lb 4400 kg
Spindle Speed 12000 rpm 12000 rpm
Spindle Power 30.0 hp 22.4 kW
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
HAAS ROTARY HAAS MACHINE ROTARY FIT TYPE
HA2TS VM-2 ALTERNATIVE FIT: CAUTION
HA5C VM-2 POSITIVE FIT
HA5C2 VM-2 ALTERNATIVE FIT: CAUTION
HA5C3 VM-2 ALTERNATIVE FIT: CAUTION
HA5C4 VM-2 ALTERNATIVE FIT: CAUTION
HA5CS VM-2 POSITIVE FIT
HRC160 VM-2 POSITIVE FIT
HRC210 VM-2 POSITIVE FIT
HRT160 VM-2 POSITIVE FIT
HRT160-2 VM-2 ALTERNATIVE FIT: CAUTION
HRT160SP VM-2 POSITIVE FIT
HRT160SS VM-2 POSITIVE FIT
HRT210 VM-2 POSITIVE FIT
HRT210-2 VM-2 ALTERNATIVE FIT: CAUTION
HRT210SP VM-2 POSITIVE FIT
HRTA5 VM-2 POSITIVE FIT
HRTA6 VM-2 POSITIVE FIT
T5C VM-2 POSITIVE FIT
T5C2 VM-2 POSITIVE FIT
T5C3 VM-2 POSITIVE FIT
TR160 VM-2 POSITIVE FIT
TR160-2 VM-2 POSITIVE FIT
TR200Y VM-2 ALTERNATIVE FIT: CAUTION
TRT100 VM-2 POSITIVE FIT
TRT70 VM-2 POSITIVE FIT
TRT160 VM-2 ALTERNATIVE FIT: CAUTION
HRT100 VM-2 POSITIVE FIT
HRT210HT VM-2 POSITIVE FIT
HRT210SS VM-2 POSITIVE FIT
TH240 VM-2 POSITIVE FIT
TRT210 VM-2 POSITIVE FIT
HA5C-T VM-2 POSITIVE FIT
HA5C3-T VM-2 ALTERNATIVE FIT: CAUTION
HA5C4-T VM-2 ALTERNATIVE FIT: CAUTION
Talk to Us
Other Similar Machines
affordable alternative
Haas VF-2
VF-2
CNC Vertical Mill with 30" x 16" x 20" travels
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
  • 20 Tool Capacity
    CNY ONLY
Learn More Build & Price
LARGER WORK ENVELOPE
Haas VM-3
VM-3
CNC Vertical Mold Machine with 40" x 26" x 25" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
    CNY ONLY
HIGHER PRODUCTION
Haas VF-2SS
VF-2SS
Super-Speed CNC Vertical Mill with 30" x 16" x 20" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
    CNY ONLY
Through-Tool Air Blast – TAB
Haas TAB functions just like through-spindle coolant, except uses a high-pressure, high-volume blast of air. When you can’t use coolant, but need to clear those chips, check out TAB.
Minimum Quantity Lubrication System
Can’t use water-based coolant on your parts . . . but still need to keep your cutting tools lubricated? The Haas Minimum Quantity Lubrication System can help you out.
Avoiding a Crash
In this Haas Tip of the Day, Mark gives some pointers on using settings in the Haas control to keep from breaking your tool – or worse!
How to Start A Mold in the Middle of The Program
Have you ever had your power go out right in the middle of your program? Or maybe you broke a tool, or needed to change an insert, or wanted to inspect your part during the finish pass. With Haas’ Program Restart, it’s no problem!
Replacement Parts
Replace worn out parts on your machine with genuine OEM parts. We have thousands in stock and ready to ship.
SHOP NOW
Performance Upgrades
Make your Haas machine perform even better, with high-productivity options that can be installed at your shop.
SHOP NOW
Maintenance Upgrades
Make your machine easier to operate, while reducing downtime. A variety of solutions are available.
SHOP NOW
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
