  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
VS-3
Product Image
GET QUOTE
VS-3
    CNY ONLY
    CNY ONLY
Vertical Machining Center; 150" x 50" x 50" (3810 x 1270 x 1270 mm)
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Coming soon. Contact your local HFO for availability.
Note: Pre-productions specifications and dimensions; subject to change without notice.
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Specs
  • Gallery
  • Operator’s Manual
Standard Features
  • 7500-rpm Spindle
  • 50+1 Side-Mount Tool Changer
  • Window Air Blast
  • Chip Auger
  • 95-Gallon Coolant Tank
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • HaasDrop
  • Remote Jog Handle with Touchscreen Display
  • Rigid Tapping
  • Second Home Position
Warranty
  • 1-Year Standard Warranty
Available Options
The Haas VS-3 is a large-frame, bed-style machining center that provides large travels and heavy-duty cutting capacity in a vertical spindle format. The machine features a 50-taper, geared-head spindle and a 50+1 tool side-mount tool changer. The fully supported X-axis travels easily handle parts weighing up to 10,000 lb.
  • 50+1 side-mount tool changer, with available 120-pocket chain style
  • Fixed enclosure; does not move with the table
  • 4 chip augers, with available in-tank conveyor
  • Control pendant on moveable stand for easy access
  • Fully supported X-axis travel
  • 50 mm ballscrews on all axes
  • 10,000 lb part capacity
  • 150" x 46" table
VF-3 Cutting Demo
Our large-frame 50-taper VMC gives the ultimate flexibility for large and heavy parts. It provides 150" x 50" x 50" (3810 x 1270 x 1270 mm) travels, heavy-duty cutting capacity, and a massive T-slot table that handles parts up to 10,000 lb.
Travels S.A.E METRIC
X Axis 150.0 in 3810 mm
Y Axis 50.0 in 1270 mm
Z Axis 50.0 in 1270 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 7500 rpm 7500 rpm
Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Taper CT or BT 50 CT or BT 50
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Table S.A.E METRIC
Length 150.0 in 3810 mm
Width 46.0 in 1168 mm
Max Weight on Table (evenly distributed) 10000 lb 4536 kg
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Air Required 4 scfm @ 100 psi 113 L/min @ 6.9 bar
Inline Air Hose 3/8 in 3/8 in
Coupler (Air) 3/8 in 3/8 in
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Other Similar Machines
C-Frame VMC
Haas VF-1250
VF-12/50
CNC Vertical Mill with 150" x 32" x 30" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
Different Approach
Haas GM-2-5AX
GM-2
3-Axis CNC Gantry Mill
  • 40 Taper
  • 3 Axis
  • 8.1k RPM
    CNY ONLY
Horizontal Spindle
Haas EC-1600ZT
EC-1600ZT
CNC Horizontal Mill with 64" x 50" x 40" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
    CNY ONLY
High-Performance 50-Taper Spindle
Do you need to increase your material removal rates? Our high-performance 50-taper spindle options use a powerful 60 hp vector drive system to push the boundaries to new limits. If you want to cut more chips in less time, watch now to see how we can maximize your material removal rates!
AVAILABLE 120-TOOL CHANGER
This optional 120-tool chain-style tool changer provides plenty of locations for back-up tooling, or setting up tools for multiple jobs. It is the perfect choice for high-volume production and long part runs, or high-mix, low-volume machining.
The hydraulically actuated tool change mechanism minimizes non-cutting time, and the servo-driven chain allows direct positioning to any tool in the carousel to reduce cycle times. With adjacent pockets empty, the tool changer allows oversize tooling up to 10" (254 mm) diameter, and weighing up to 35 lb (16 kg).
  • Servo-driven chain-style tool changer
  • Hydraulically actuated tool change mechanism
  • Dedicated area for manually loading/unloading tools
  • Pocket Tool Table in the control allows complete control over the tool changer
  • Identify tools as LARGE to leave adjacent pockets empty
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
