  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
UMC-1600-H
Product Image
GET QUOTE
UMC-1600-H
    CNY ONLY
    CNY ONLY
5-Axis CNC Horizontal Mill with 64" x 50" x 40" travels
  • 50 Taper
  • 5 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
Available Q1 2021
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Details
  • Specs
  • Gallery
  • Send Info
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
Standard Features
  • 7500-rpm Spindle
  • 50+1 Side-Mount Tool Changer
  • 5th-Axis Drive and Wiring
  • Built-In 4th-Axis Rotary Platter
  • Wireless Intuitive Probing System
  • Enclosure Exhaust System
  • Chip Auger
  • 95-Gallon Coolant Tank
  • Variable Flow Coolant
  • CNC Control Cabinet Cooler
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • HaasDrop
  • Remote Jog Handle with Touchscreen Display
  • Rigid Tapping
  • Dynamic Work Offsets and Tool Center Point Control
  • Second Home Position
  • Internal High-Voltage Isolated Transformer
Warranty
  • 1-Year Standard Warranty
Available Options
The UMC-1600-H is a 50-taper Universal Machining Center based on our highly popular EC-1600ZT HMC. We’ve mounted a massive 630 mm rotary table to the machine’s integrated 4th-axis platter to provide 3+2 positioning and full 5-axis motion for machining large parts.
The machine’s 50-taper cutting ability, heavy-duty rotary axes, and large work envelope make it the perfect 5-axis solution for the large parts found in the oil & gas, alternative energy, and other heavy industries.
  • ±120° of B-axis swing and 360° of C-axis rotation
  • 50-taper spindle with a 2-speed gearbox
  • Standard side-mount tool changer, 50+1 tools
  • Includes DWO/TCPC and Wireless Intuitive Probing System
  • 78" max part swing on integrated 4th axis
  • Made in the USA
Overview
The UMC-1600-H is a full 5-axis, 50-taper universal machining center based on our extremely popular EC-1600ZT HMC frame. The 5th axis has a generous 630 mm (24.8") diameter rotary platter, with a 257 mm (10.125") through-bore.
All of the standard machine specifications and features of the EC-1600 Series models have been incorporated into this completely new 5-axis machine. See a detailed video on the construction and design improvements of the EC-1600 Series models HERE.
To provide full, simultaneous 5th-axis motion, we mounted our all-new heavy-duty HRT630 rotary table to the integrated 4th-axis platter of our EC-1600ZT, using a purpose-built casting. This heavy-duty configuration provides large part capacity and 50-taper machining capabilities for larger 5-axis projects. The 5th-axis has a maximum swing diameter of 48" (1219 mm), and can handle parts up to 1500 lb (680 kg) unsupported, or up to 3000 lb (1361 kg) with an optional outboard support.
Extra-Large 5th-Axis Rotary Table
The main feature that distinguishes the UMC-1600-H from the EC-1600ZT is the addition of our HRT630 rotary table as the 5th axis. This extra-large HRT Series rotary table is perfect for holding large workpieces or fixtures for 5-axis machining. The high-capacity, heavy-duty table is mounted vertically with a unique casting designed for use in this model, and it feature a large through-hole for bar feeding and special fixture-locating requirements. Chucks and fixtures can easily be bolted to the platter using the precision T-slots. See below for other available platter options.
Key Rotary Specification Comparison UMC-1600-H EC-1600ZT-5AX
4th-Axis Travel
±120° ± 30°
5th-Axis Platter Diameter 24.8" (630 mm) 12.2" (310 mm)
5th-Axis Through-Bore Diameter 10.125" (257.18 mm) 3.25" (82.6 mm)
5th-Axis Number of Standard T-Slots 8 each @ 45° 6 each @ 60°
5th-Axis Part Swing Diameter 48" (1219 mm) 37.2" (945 mm)
5th-Axis Max Weight on Platter (w/Support) 3000 lb (1361 kg) 435 lb (197 kg)
5th-Axis Max Weight on Platter (Unsupported) 1500 lb (680 kg) 218 lb (99 kg)
5th-Axis Max Speed 50° / Second 75° / Second
Brake Torque  @ 100 psi/6.9 bar 4000 ft-lbf (5423 Nm) 500 ft-lbf (678 Nm)
Backlash 30 arc-sec 30 arc-sec
Accuracy ± 15 arc-sec ± 15 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Standard T-Slot Platter
The standard T-slot platter is 630 mm (24.8") outside diameter, with a 10.125" (257.18 mm) through-bore. It features 8 standard T-slots equally spaced at 45 degrees.
The optional short support can be used to attach a tailstock or other support device. A long support will also be available (see image below).
Optional Platter With Hole Patterns for Mounting Sub-Plates
An optional platter with multiple bolt-hole patterns is available in place of the standard T-slot platter. This optional platter is also 630 mm (24.8") outside diameter, with a 10.125" ( 257.18 mm) through-bore diameter.
The optional long support can be used to attach a tailstock or other support device. A short support will also be available (see image above).
Optional Platter With A1-20 Spindle Nose For Mounting Chucks
The optional platter with A1-20 spindle nose is available for easy, accurate mounting of aftermarket chucks.
Productivity options may include a mill vise mounting location, and possible steady rest options
3-Jaw Manual Chuck Mounted on A1-20 Platter Option
The optional platter with A1-20 spindle nose is shown with a 3-jaw manual chuck mounted.
The optional long support with the optional manual rotary tailstock.
3-Jaw Pneumatic Chuck Mounted on A1-20 Platter Option
The optional platter with A1-20 spindle nose is shown with a 3-jaw pneumatic chuck mounted.
The optional long support with the optional A-frame support.
Travels S.A.E METRIC
X Axis 64.0 in 1626 mm
Y Axis 50.0 in 1270 mm
Z Axis 40.0 in 1016 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 7500 rpm 7500 rpm
Max Torque 340.0 ft-lbf @ 700 rpm 460.0 Nm @ 700 rpm
Drive System 2-Speed Gearbox 2-Speed Gearbox
Taper CT or BT 50 CT or BT 50
Integrated 4th Axis (B Axis) S.A.E METRIC
Platter Diameter 30.00 in 762 mm
Travel ± 120 ° to 120- ° 120 ° to 120- °
Max Part Swing 78.0 in 1981 mm
Max Rating 5.0 hp 3.7 kW
Rotational Torque (continuous) 2000 ft-lbf 2712 Nm
Gear Ratio 500:1 500:1
Brake Torque 4000 ft-lbf 5423 Nm
Min Resolution 0.001 ° 0.001 °
Indexing Accuracy ± 30 arc-sec ± 30 arc-sec
Repeatability 15 arc-sec 15 arc-sec
C Axis S.A.E METRIC
Travel 360 ° 360 °
Platter Diameter 24.80 in 630 mm
Through-Bore Diameter 10.125 in 257.18 mm
Number of Std T-Slots 8 EA @ 45 ° 8 EA @ 45 °
Max Speed 50 °/sec 50 °/sec
Max Part Swing 48.0 in 1219 mm
Max Weight on Platter (w/support) 3000 lb 1361.0 kg
Max Weight on Platter (unsupported) 1500 lb 680.0 kg
Accuracy (±) ± 15 arc-sec ± 15 arc-sec
Feedrates S.A.E METRIC
Max Cutting 500 ipm 12.7 m/min
Rapids on X 600 ipm 15.2 m/min
Rapids on Y 600 ipm 15.2 m/min
Rapids on Z 600 ipm 15.2 m/min
Axis Motors S.A.E METRIC
Max Thrust X 4000 lbf 17793 N
Max Thrust Y 8000 lbf 35586 N
Max Thrust Z 8000 lbf 35586 N
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 50+1 50+1
Max Tool Diameter (full) 4.0 in 102 mm
Max Tool Diameter (adjacent empty) 10.0 in 254 mm
Max Tool Length (from gage line) 20 in 508 mm
Max Tool Weight 30 lb 13.6 kg
Tool-to-Tool (avg) 8.0 s 8.0 s
Chip-to-Chip (avg) 12.6 s 12.6 s
Air Required 9 scfm @ 100 psi 255 L/min @ 6.9 bar
Spindle Speed 7500 rpm 7500 rpm
Spindle Power 30.0 hp 22.4 kW
Domestic Pallet 192 in x 166 in x 136 in 486 cm x 422 cm x 345 cm
Weight 31200 lb 31200 lb
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Talk to Us
Other Similar Machines
DIFFERENT APPROACH
Product Image
VF-6/50TR
Trunnion CNC Vertical Mill with 64" x 32" x 30" travels
  • 50 Taper
  • 5 Axis
  • 7.5k RPM
  • 30+1 Tool Capacity
    CNY ONLY
Learn More Build & Price
40-Taper, Smaller Machine
Haas UMC-1000
UMC-1000
5-Axis CNC Vertical mill with 40" x 25" x 25" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
    CNY ONLY
Different Approach
Haas EC-1600ZT-5AX
EC-1600ZT-5AX
  • 50 Taper
  • 5 Axis
  • 7.5k RPM
    CNY ONLY
WITH DWO/TCPC THERE’S NO NEED TO:
✗   Place the part in the exact same location every time
✗    Repost the program when the fixture changes
✗    Repost the program if the job moves to another Haas machine
DWO/TCPC CHANGES EVERYTHING:
✓   Save time on programming and setup
✓   Reduce fixturing costs
✓   Increase your number of multi-axis operators
✓   Increase your productivity and profits
Replacement Parts
Replace worn out parts on your machine with genuine OEM parts. We have thousands in stock and ready to ship.
SHOP NOW
Performance Upgrades
Make your Haas machine perform even better, with high-productivity options that can be installed at your shop.
SHOP NOW
Maintenance Upgrades
Make your machine easier to operate, while reducing downtime. A variety of solutions are available.
SHOP NOW
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
