  • machines
    • Haas Vertical Mills
      • Drill/ Tap/ Mill Series
      • Vertical Mill/Turn
      • Mill Auto Parts Loader
    • Product Image
    • Haas Lathes
      • Lathe Auto Parts Loader
    • Haas Horizontal Mills
    • Haas Rotaries & Indexers
    • Product Image
      • Robot Systems
      • Pallet Pool Systems
      • Haas Bar Feeder
      • Models
    • QUICK LINKS Special Series  Special Series  PRICE LIST PRICE LIST BUILD & PRICE BUILD & PRICE WHAT’S NEW WHAT’S NEW
  • Options
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Haas Chip & Coolant Management
    • Product Image
    • Product Image
    • Product Image
    • Product Image
    • Product Image
      Automation
      • Automation
      Why Haas MyHaas HTEC Network Industry 4.0 Haas Certification Customer Testimonials
  • Service
    • SEARCH ALARM CODES
      Search
    • Troubleshooting Guides and How-To Procedures
      • Product Image
      • Product Image
        How To Procedures
    • Manuals
      • Product Image
        Operator Manuals
      • Product Image
        Interactive Service Manuals
  • Videos
  • MyHaas – One Place for Everything
    • Compare Quotes
      • Compare Quotes
    • About MyHaas
      • About MyHaas
    • Haas CNC Certification Program
    • Haas Learning Resources
      Milling Chucks, Collets & Kits
      Drill Chucks
      Pull Studs
      Mill Toolholding Kits
      Vises
      Mill Vise Jaws
      Workholding Accessories
      Milling
      End Mill Kits
      HSK Toolholders
      HSK ER Collet Chucks
      HSK Shell Mill Holders
      Cut-Off Tooling
      Grooving Tools
      Small ID Grooving & Threading Tools
      Threading Toolholding
      ID Toolholding
      OD Toolholding
      ER Collet
      ER Collets & Accessories
      ER Collet Kits
      Tool Management
      Spindle Taper Cleaner
      Tool Kits
      End Mill Kits
      Indexable Milling Kits
      Part #
      Part #
      Mill Toolholding Mill Workholding Milling HSK Toolholders Lathe Tooling Lathe Workholding ER Collet Holemaking Threading Tool Management Tooling Accessories Tool Kits Apparel & Accessories
My Cart
Find A Dealer
    3. Español
    7. Česky
    13. Русский
    19. Български
Search
EC-400
Product Image
GET QUOTE
EC-400
    CNY ONLY
    CNY ONLY
400 mm Twin-Pallet HMC with 22" x 25" x 22" travels
  • 40 Taper
  • 4 Axis
  • 8.1k RPM
  • 30+1 Tool Capacity
Compare Machines
BUILD & PRICE
Contact Distributor
  • Overview
  • Details
  • Specs
  • Gallery
  • Send Info
  • Installation Guide
  • Layout Drawing
  • Torque Chart
  • Operator’s Manual
  • EC-400 Series Flyer
Standard Features
  • 8100-rpm Spindle
  • 30+1 Side-Mount Tool Changer
  • Window Air Blast
  • Belt-Type Chip Conveyor HMC
  • 95-Gallon Coolant Tank
  • Variable Flow Coolant
  • CNC Control Cabinet Cooler
  • Control Touch Screen
  • Media Display M-Code; M130
  • Ethernet Interface
  • HaasDrop
  • Rigid Tapping
  • Second Home Position
  • Internal High-Voltage Isolated Transformer
  • 4th-Axis Rotary Scales
  • EC-400 Pallet Kit, Inch
  • EC-400 Pallet Kit, Metric
Shipping
  • Lifting Provision
Warranty
  • 1-Year Standard Warranty
Available Options
Designed for high-volume production and unattended operation, the all-new EC-400 is faster, more compact, more rigid, and more capable than ever before. It features a larger work envelope, faster rapids, full 4th-axis pallet indexing, and much better chip management. For extended production and true “lights out” capability, a 6-station pallet pool and high-capacity tool changer are available. NOTE: The Pallet Pool requires the optional 50+1 or 100+1 side-mount tool changer.
  • Standard 30+1 tool side-mount tool changer,  with options for 50+1 or 100+1
  • Built-in pallet changer with 400 mm pallets
  • Full 4th-axis indexing
  • Available 6-station pallet pool
  • Made in the USA
EC-400
The completely redesigned EC-400 has been improved from the ground up, with all new castings for increased rigidity and better cutting performance, 5 more inches of Y-axis travel, vastly improved chip evacuation, and an available 100-pocket tool changer. See how Haas engineers have taken our latest HMC to the next level.
Overview
When Haas Automation set out to improve our already-popular 400 mm pallet-changing horizontal machining center, we analyzed customer feedback, and the result is a fantastic machine tool that has even the most skeptical machinists singing its praises.
Specification Comparison (Inch)
  NEW MODEL PREVIOUS MODEL
Axis Travels (X, Y, Z) 22" x 25" x 22" 20" x 20" x 20"
Maximum Optional Spindle Speed 15,000 rpm 12,000 rpm
Tool Changer Capacity 30+1 24+1
Optional Tool Changer Capacity 50+1, 100+1 40+1, 70+1
Rapids (X, Y, Z) 1400 in/min 1000 in/min
Maximum Feedrate 833 in/min 500 in/min
90° Rotation Time 3 sec 5.5 sec
Maximum Weight on Pallet 880 lb 660 lb
Rotational Torque (Continuous) 424 ft-lb 300 ft-lb
Specification Comparison (Metric)
Axis Travels (X, Y, Z) 559 x 635 x 559 mm 508 x 508 x 508 mm
Rapids (X, Y, Z) 35.6 m/min 25.4 m/min
Maximum Feedrate 21.2 m/min 12.7 m/min
Maximum Weight on Pallet 400 kg 300 kg
Rotational Torque (Continuous) 575 Nm 407 Nm
EC-400 Chip Management
The completely redesigned EC-400 has been improved from the ground up, with all new castings for increased rigidity and better cutting performance, 5 more inches of Y-axis travel, an available 100-pocket tool changer, and vastly improved chip evacuation.
At the heart of the EC-400’s improved chip management system is a wider belt-type chip conveyor positioned in the center of the machine, directly under the spindle. The steep walls of the interior enclosure easily funnel chips to the conveyor.
The conveyor discharges chips at the height of a full-size industrial barrel. Washdown nozzles mounted in the ceiling are fed by a separate coolant pump, and allow you to direct coolant flow to areas where chips may gather, to further enhance chip evacuation.
EC-400 Coolant Ring
The 4-nozzle coolant ring surrounding the spindle nose is perfectly positioned so that nozzles can be pointed at the shortest tools, and others can be positioned for longer tools. The compact, cylindrical design prevents chips from collecting on top. NOTE: The Haas Programmable Coolant Nozzle (P-COOL) is not available on the EC-400.
EC-400 Pallet Schedule Table
In previous Haas pallet-changing machines, the G188 code was used to call a part program from the Pallet Schedule Table (PST), based on which pallet was loaded. Continuous operation was achieved by running a main program that consisted of an M50 to perform a pallet change, the G188 to call the program for the loaded pallet, and an M99 to loop the whole process. The M50 loaded the next scheduled pallet, and the G188 called the program designated for that pallet.
With the G188, however, if you restarted your machining process in the middle of one of the pallet programs, it didn’t allow you to get back to the main program to continue uninterrupted machining. You had to wait for your restarted program to finish, select your main program again, and then start your continuous cycle.
We developed a new M-code to solve this problem. The M199 is used at the end of a program. When the program is started by pressing [CYCLE START] in Memory mode, the M199 acts exactly like an M30 (Program End and Reset). But if the program is started by pressing [INSERT] while the Pallet Schedule Table is displayed, the M199 will command a pallet change to load the next scheduled pallet, and then run the program associated with that pallet. This allows the user to start machining on any pallet, and continue uninterrupted machining, as long as pallets are scheduled.
EC-400 Cycloidal Rotary Drive
The cycloidal rotary drive system – designed for machine tools and robotics – provides a great combination of speed, accuracy, and durability to the B axis. The rugged design provides long service life, with little or no maintenance, and is especially durable in a crash. The cycloidal rotary drive can be back driven to absorb energy from an impact. The shock-load capacity is 5 times the rated torque of the gearbox, and the entire gearbox is a simple drop-in replacement, should damage occur.
EC-400 Hydraulic Pallet-Clamping System
The hydraulic power unit provides power to clamp the pallets to the pallet receiver, as well as raise and lower the pallet-changer mechanism.
EC-400 Increased Axis Travels
An extra 5" (127 mm) of Y-axis travel can make all the difference in the world. Now, the spindle centerline can get 27.13" (689 mm) above the surface of the pallet. We also increased the X- and Z-axis travels by 2" (51 mm) each.
EC-400 Stepped Base and Column
The stepped base and column design of the EC-400, where one X-axis linear guide rail is on a different horizontal plane than the other, increases the rigidity and stability of the spindle-head column assembly. With hydraulic pallet clamping and the stepped base/column design, the EC-400 is more rigid than ever, all the way to the top!
EC-400 Automatic Probe Riser
An automatic probe arm stores the tool setting probe in a protective compartment during machining operations. When the tool probe is needed, an M104 code activates the automatic probe arm to lift the probe and lock it into place. When probing is complete, an M105 retracts the probe to its protective compartment.
Travels S.A.E METRIC
X Axis 22.0 in 559 mm
Y Axis 25.0 in 635 mm
Z Axis 22.0 in 559 mm
Spindle S.A.E METRIC
Max Rating 30.0 hp 22.4 kW
Max Speed 8100 rpm 8100 rpm
Max Torque 90.0 ft-lbf @ 2000 rpm 122.0 Nm @ 2000 rpm
Taper CT or BT 40 CT or BT 40
Bearing Lubrication Air / Oil Injection Air / Oil Injection
Cooling Air Cooled Air Cooled
Integrated 4th Axis (B Axis) S.A.E METRIC
90° Rotation Time (full 4th) 3.0 s 3.0 s
Max Weight on Platter 880 lb 400.0 kg
Rotational Torque (continuous) 424 ft-lbf 575 Nm
Backlash 30 arc-sec 30 arc-sec
Gear Ratio 106:1 106:1
Min Resolution 0.001 ° 0.001 °
Indexing Accuracy ± 15 arc-sec ± 15 arc-sec
Repeatability 10 arc-sec 10 arc-sec
Rapids on B 150 °/sec 150 °/sec
Pallet Changer S.A.E METRIC
Pallet Quantity 2 2
Pallet Length 15.75 in 400 mm
Pallet Width 15.75 in 400 mm
Max Pallet Load 880 lb 400.0 kg
Pallet Change Time 15 s 15 s
Feedrates S.A.E METRIC
Max Cutting 833 ipm 21.2 m/min
Rapids on X 1400 ipm 35.6 m/min
Rapids on Y 1400 ipm 35.6 m/min
Rapids on Z 1400 ipm 35.6 m/min
Axis Motors S.A.E METRIC
Max Thrust X 3380 lbf 15035 N
Max Thrust Y 2810 lbf 12500 N
Max Thrust Z 3380 lbf 15035 N
General S.A.E METRIC
Coolant Capacity 95 gal 360 L
Tool Changer S.A.E METRIC
Type SMTC SMTC
Capacity 30+1 30+1
Max Tool Diameter (full) 2.5 in 64 mm
Max Tool Diameter (adjacent empty) 5.0 in 127 mm
Max Tool Length (from gage line) 12 in 305 mm
Max Tool Weight 12 lb 5.4 kg
Tool-to-Tool (avg) 2.8 s 2.8 s
Chip-to-Chip (avg) 3.6 s 3.6 s
Air Required 9 scfm @ 100 psi 255 L/min @ 6.9 bar
Inline Air Hose 1/2 in 1/2 in
Coupler (Air) 1/2 in 1/2 in
Air Pressure Min 100 psi 6.9 bar
Spindle Speed 8100 rpm 8100 rpm
Spindle Power 30.0 hp 22.4 kW
Domestic Pallet 202 in x 100 in x 112 in 513 cm x 254 cm x 284 cm
Export Crate 176 in x 92 in x 101 in 447 cm x 234 cm x 257 cm
Weight 17520 lb 7947.0 kg
Talk to Us
Note: Pallets are not interchangeable with the previous generation EC-400.
*Haas machines are designed to operate on 220 VAC power. An optional internal high-voltage transformer (380 - 480 VAC) is available for all models, except the Desktop Mill, CL-1, and CM-1.
Note: This optional high-voltage internal transformer is not field installable; it must be ordered with the machine.
Available 6-Station Pallet Pool
Whether you’re doing high-volume production runs, high-mix/low volume machining, or just want to run lights-out, you can boost the productivity of your EC-400 with our fully integrated 6-station pallet pool. NOTE: The Pallet Pool requires the optional 50+1 or 100+1 side-mount tool changer. Not field installable. Must be ordered with a new EC-400.
Learn More
Making a Great Machine Tool Even Better
  • Available 100-Pocket Tool Changer for High-Volume Production
  • Increased Y-Axis Travel for More Capacity
  • Stepped Casting for Greater Stability
  • Rear Chip Discharge Saves Valuable Shop Floor Space
Other Similar Machines
VERTICAL SPINDLE
Haas VF-3SSYT
VF-3SSYT
Super-Speed CNC Vertical Mill with 40" x 26" x 25" travels
  • 40 Taper
  • 3 Axis
  • 12k RPM
    CNY ONLY
Learn More Build & Price
DIFFERENT APPROACH
Haas UMC-750
UMC-750
5-Axis CNC Vertical Mill with 30" x 20" x 20" travels
  • 40 Taper
  • 5 Axis
  • 8.1k RPM
  • 30-50 Tool Capacity
    CNY ONLY
50-TAPER POWER
Haas EC-1600
EC-1600
CNC Horizontal Mill with 64" x 50" x 32" travels
  • 50 Taper
  • 3 Axis
  • 7.5k RPM
  • 50+1 Tool Capacity
    CNY ONLY
HAVE QUESTIONS? WE HAVE THE ANSWERS.
FIND DISTRIBUTOR
  • HTEC Network
  • Twitter
© 2021 Haas Automation, Inc – CNC Machine Tools
Cookie Notice
Manage Settings
Cookie Notice
Functional Cookies
Analytics Cookies
